My Toyota Corolla SE Saloon Automatic has developed an abnormal cranking sound in the engine. This sound had developed six months back. This olny comes at high RPM .If I drive at less than 2000 rpm it is barely noticeable. I went to different local mechanics but all have diagnosed different problems. I also took it to Toyota Southern motors but they claimed that the problem will be identified only after opening the engine. One mechanic told me it was the sound of Exhaust manifold and it will be removed after replacing it. I told him to replace it and if the sound doesn't go away I won't pay him any money. I got the manifold changed but still the sound didn't go away so I again replaced my old manifold. Another mechanic told me that I had to replace the entire engine costing 80,000 PKR from Shershah!!
The car is running fine just the sound is disturbing me. None of the mechanics have diagnosed similar problem so I doubt which one to trust and I am also told that these mechanics are not expert in Automatic engines.
Need help if similar problem occurred with anybody else or if any of you can recommend me a good mechanic. I want to get it repaired before it gets worse.
P.S The sound is more prominent when the engine is cold.
Thanks
