Well, well, well. I see many people on here totally confused, and also giving very inaccurate information, as usual.
Car manufacturers in Europe that were charging vehicles with R-1234yf refrigerant, kept in mind that in the case of anything unexpectedly going wrong in the future, that the cars were ALREADY EQUIPPED AND COMPATIBLE to handle R-134a refrigerant!! I almost forgot to mention you must ALSO replace the metering device (expansion valve block) as well, because the expansion valve for R-1234yf is different than R-134a.
In FACT, Denso (Which is the compressor used in most Toyota's, Honda's and even Mercedes-Benz) has said that the COMPRESSOR OIL used for R-1234yf IS ALSO COMPATIBLE with R-134a, should the car manufacturer need to revert BACK to R-134a.
What is NOT COMPATIBLE, are the OLD COMPRESSOR OILS specifically for R-134a, you CANNOT use with R-1234yf!! So, for Toyota's example with a Denso Compressor, you CANNOT USE ND-8 Compressor oil with R-1234yf. BUT, if you have a Toyota car with ND-12 Compressor Oil, then it is FULLY COMPATIBLE with R-134a as well!
So as to your question with your Honda Civic 10th Gen Hatchback, Made in the UK, YES, you CAN use R-134a refrigerant in place of R-1234yf. You, however, CANNOT add the PREVIOUS PAG46 compressor oil, to your car! You will need to add the NEW ND-12 Compressor Oil ONLY! DO NOT MAKE THIS MISTAKE!
I was able to purchase the couplers to fit R-1234yf Low and High Side fittings, with my R-134a gauge set, replaced the expansion block valve to a R-134a expansion valve and was able to charge a European Model car with R-134a, and the cars air conditioning system is working perfect and blowing REALLY cold air! I had to recover ALL the old R-1234yf refrigerant, pull a vacuum, add the CORRECT COMPRESSOR OIL FOR THE CAR, and then added the R-134a based on the weight information from the car manufacturer!
By the way, Daimler Benz had a HUGE issue with R-1234yf refrigerants at first, so they retrofitted R-134a BACK into many models! So if Mercedes-Benz trained their DEALERSHIPS in Europe on how to do this, on cars that ORIGINALLY HAD R-1234yf, then they must know better, correct?
