Hi
Corolla AE100 5A-FE engine. 246000Km Odometer.
when cold start (around 27 degrees C) car start fine and idle around 900-1000rpm. if I turn on AC, engine suddenly become slow and AC clutch disengage to prevent engine stall. sometimes engine stall. when I drive, car feel lack of power.
this car idle 800-900rpm when warm. turning on ac, slight increase rpm and runs fine. no idle drop.
this happen only when engine cold.
I checked coolant temp sensor, IAC valve, throttle body, TPS. all within specs. what could be the problem? low compression?
I heard this engine should run 1300-1400 rpm as soon as cold start. but mine never run at this speed when cold.
