First ALL MOTOR SETUP in Karachi on a motor bike :)
Hv installed wiseco hi compression alluminium - forged piston 61mm - 13mm pin
hi performance racing cam shaft
Hi performance 55mm stroker crank
cylinder stud kit
hv installed titanium valve springs retainer
bigger intake and exhaust valve
30mm intake valve
24.5 exhaust valve
5mm valve stem
ceramic coating alluminium cylinder
kitaco oil pump kit
racing CDI with harness
Hv installed silver head gaskit 1mm
but the problem is tht i cant control its knocking
increase head gaskit size to 1.5mm but no result then 1.75mm find result so thought knocking is dere becuase of lean fuel so increase the fuel by havng bigger jets first the jet size was 92 then installed 104.. knocking ends in 1st and 2nd gear in 3rd it do little knocking and in 4th when accelarate it it starts knocking..
Help advice required plz
