you need thorough revamping of your 2E toyota corolla engine.
i own 1990 EE-90 2E carb engine auto transmssion in city drive i get 8km / litre with ac vehicle is 120,000 km after 3rd engine overhaul it consumes 500 ml engin eoil after 5000 kms zero smoke.
it has size 15 wheels
it has the same engine as Indus 1st gen ae100, and carburator is available across all scrapyards in Pindi Karachi, Lahore & Peshawer
- check the distributor, ignition cables, vaccum pods.
- connect all vaccum tubes with respective pods
- insert thermostat valve into cooling system
- connect cooling fans to run on automatic
- use coolant & change the radiator cap ( 0.9 bar )
- change tranmission oil
