Plz, cross check the connections', It There seems to be a problem with Green wire.
Will check.
Last night the back light was working, but the light on its pointer turns off after 1 min of car starting, and stays off
You can visit Electrician Maani for making it functional
If in Khi then where is he available?
Following post is by @brownrose78,
Complete post can be seen here
Got it 🏼🏼
Anyone knows for headlight beam adjustment, which screw\gear is rotated for beam up and down.
There are 2 on each light... One screw\gear is approached from straight top, and the other is approached frm top too, but diagonally.
Off topic, since City thread is not that active.
Some idiot threw some shit(diaper) probably from their balcony onto our car bonnet... apparently the city is their garbage can
I got it cleaned from the service station, but the nishaan(stains) are still there, as seen from an angle in the pic below...can anyone advise how can it be cleaned properly so that it doesnt looks bad.
it will need some slight compounding.
Thanks.. any idea, where in Khi this is possible? Hope its not expensive.
Is there any risk of leaving it as it is? Would it get permanent?
it looks like clear coat or polish damage due to acidic nature of human excrement.
majority of painters can do rubbing/compounding
Got it.. if i delay this, will it get permanent and hard to clean later?
washing with plenty of water should get rid of the acidic effect.. but better to get it done asap.
better to take opinion of professional painters first
1 more thing for same City... Left headlight was fused, so got another one installed... But noticed later that the new one is 90W, while the original was 60W... Would it have any effect on wiring or battery life?... Or would it hamper Vision of drivers coming frm opposite side?
Change it ASAP, It can damage housing, and also cause FIRE.
Sheeet... ... Would it be available at water pump, in Khi? ... Any idea?
Yes easily.
Got the light bulb
Back to topic\Alto... Noticed oil spitting from the silencer in morning\cold start up... What could be the reason... Oil change is due though.. should i replace it already or get the oil spitting work done first
Are you sure it is oil? It is most likely carbon mixed with water (steam).
