Hybrid fuel (dual mode)
Ford Escape Plug-in Hybrid with a flexible fuel capability to run on E85 (ethanol)
In addition to vehicles that use two or more different devices for propulsion, some also consider vehicles that use distinct energy sources or input types ("fuels")
using the same engine to be hybrids, although to avoid confusion with
hybrids as described above and to use correctly the terms, these are
perhaps more correctly described as dual mode vehicles:
Some electric trolleybuses can switch between an on-board diesel engine and overhead electrical power depending on conditions (see dual mode bus). In principle, this could be combined with a battery subsystem to create a true plug-in hybrid trolleybus, although as of 2006, no such design seems to have been announced.Flexible-fuel vehicles can use a mixture of input fuels mixed in one tank — typically gasoline and ethanol, methanol, or biobutanol.Bi-fuel vehicle: Liquified petroleum gas and natural gas
are very different from petroleum or diesel and cannot be used in the
same tanks, so it would be impossible to build an (LPG or NG) flexible
fuel system. Instead vehicles are built with two, parallel, fuel systems
feeding one engine. For example, some Chevrolet Silverado 2500 HDs can effortlessly switch between petroleum and natural gas, offering a range of over 1000 km (650 miles).[34] While the duplicated tanks cost space in some applications, the increased range, decreased cost of fuel, and flexibility where LPG or CNG
infrastructure is incomplete may be a significant incentive to
purchase. While the US Natural gas infrastructure is partially
incomplete, it is increasing at a fast pace, and already has 2600 CNG stations in place.[35]
With a growing fueling station infrastructure, a large scale adoption
of these bi-fuel vehicles could be seen in the near future. Rising gas
prices may also push consumers to purchase these vehicles. When gas
prices trade around $4.00, the price per MMBTU of gasoline is $28.00, compared to natural gas's $4.00 per MMBTU.[36]
On a per unit of energy comparative basis, this makes natural gas much
cheaper than gasoline. All of these factors are making CNG-Gasoline
bi-fuel vehicles very attractive.Some vehicles have been modified to use another fuel source if it is available, such as cars modified to run on autogas (LPG) and diesels modified to run on waste vegetable oil that has not been processed into biodiesel.Power-assist mechanisms for bicycles and other human-powered vehicles are also included (see Motorized bicycle).
same link just scroll below, I said Hybrid fuel. Cheers
