there is a whole thread to deal with this issue. search for it. in short since you did not make any recent changes to your system, i am guessing your ground wire has become loose. fix that and i think your problem will be solved
@enerlevel
good to hear ur back...please help me out..im looking for good speakers in the range 6k-7k...there are 3 options in my mind right now.. kenwood 718, kenwood 718ex, pioneer 6902r...also i have a pair of pioneer 6992 which is being used without an amp...i would be using them with woofer so bass is nt the issue only the quality matters...Also please suggest a good woofer in the range 4k-5k like pioneer 308 d2...thanks and waiting fr ur reply...
salam ener, i have a pioneer hu, 718speakers and a PREMIER 2channel amp.. Shuru shuru mai system fit chal raha tha.. lekin ab earth ki noise aati hai accelerator k sath koi bump se guzro tu bohut high hojati hai wht shld i do?
i agree to make it stickyit is heplful
yes bro me bak. which car is this? i would suggest u get front components as u can get sony for 4500. and then u can invest less on rear speakers because the front will sound much better.for a woofer, your best choice for the money is pioneer 308d2. make a good custom box for it and u will not regret.
check ur wires under to seat to see if it has not come under the railing of the seats...
hey ener suggest me a 2ch amp or a mono amp to run 308d2 and my range is 8k
change ur subs to 2 308d4 and then u can get alot of range of amps...vtrek , caliber , solid audio etc etc
kevin is back to awami madad
agar awam kee madad kerni hai tou iss ko chahiyae yeh flood hit areas jae...his muscles and strength will also come in handy there
@enerthanks man...i wud go for 308d2 now....but also please suggest a good amp for it...should it be mono or 2channel as 308d2 is DVC...thanks
Help needed regarding encloseri want to know which encloser is gud for pioneer ts-w3002d4 spl
ill change my woofer to d4 later on but abi which amp should i buy n within my bugdet??
u can get mono or 2 channel doesnt matter but should be atleast 400-500rms.
u should get vtrek as many ppl here have positive experience with this amps.
this amp isnt available in any shop n is outta my range.....
humm then what amps are available? mayb it will be easier to choose with some models in mind rather then firing in the dark with no target in mind ???
aaaah 3002d2.... thts one of my favourite subwoofer!!! y dont u do a thing, use the search button and search for 3001d4 (same as 3002d2) you will get many posivite inputs by me in this forum
ahahhaah (H)
