Take it to a lift - raise it and check the underbody and all rubber items - try to move them with a strong rod. If they move they need replacement. Check the ball joints and tie rods - they are weak points. Check for leaks and missing pieces.
Locate a shop that has a proper MB scan unit and ask to test all the modules in it. Specifically ask for the clutch adaptations in the gearbox to know how worn down it is. Note down all logged and previous faults.
Inspect the car generally and drive it - it should drive correctly. All functions should operate correct.
Inspect the supercharger for any noise etc and listen to the engine as it starts. If its noisy or rattly you need a timing chain job soon.
Ask the seller for all keys that they have - make sure all work.
