Yeah, I can remember that he loosened bearings in this sequence to take pressure of the cam shaft-
First, E1 bearing cam lobe was at TDC, then he went to the left bearing i.e E7, used a wrench, gave it a turn so the cam lobe faces were up, between E6 and E7. Then he proceeded to loosen every nut on the bearing E7-E1, except for E2 while his assistant was holding the wrench tightly, to avoid the cam shaft to move.
Then he loosened the nut on Bearing E2 slowly, turn by turn to relieve pressure of the Camshaft and he Turned the cam shaft using the wrench a bit as well, so it wasn't tight, but free, in a comfortable position.
Our mechanics go by instinct and when something messes up- blame goes to the manufacturer lol.
