Posted also at Cuore Fan Club
any one here can help me??
the car in question is cuore 2006.
its a long post, but plz read and help me
Sad news
Yesterday my car got heat up, I received call from my wife that the needle is going up from half point, I asked her to turn the engine off and pour water in reserve bottle. She did same, but after some time again I received call, claiming the same problem. I asked to repeat the earlier said step. The needle went upto 85% of the guage :(:'((A) (as per statement from my wife). Now when I reached home and opened bonnet, I was amazed to see that radiator cap was not there.....(A):'(. It was found fallen in engine room, I put cap back filled water, started the engine, everything was fine.
Then this morning I went to toyota walton for oil change, since I thought that high temperature engine may have caused oil to change its viscosity and It may have become thin, and may not perform its duty well now (it was only 1000 km driven since last oil change). So after oil change I was assuming that everything is fine, but now I feel that
-engine heats up to mid point more early then it used to do before (like u can say about in 25% faster time for needle to reach mid point) But it maintains it self there doesnt go above mid, and cooling system working well. Specially with AC it stays continuously at mid point.
-Earlier when I had long straight run on constant speed, the needle use to fall to about 30% of guage, even with AC, today it was not the case. (it was 12:00 noon to 1:30 noon)(today lahore has 37 degree Celsius)
so tell me
is there any problem with my engine? radiator??
or its due to hot temperature?? (remember today lahore was at 37 C)
what is the remedy? how to keep engine cool?
dear I am quite worried, is there any serious problem??
waiting for reply from all of you...
a person at toyota said to get my radiator wash, should I ?
please also check if the thermostat valve is installed and working properly.
