sealant for mercedes benz engines loctite 5800
its good stuff, but requires 4 hours set time before engine start - as usual shahnawaz ltd will look at you like you have a horn growing out of your forehead if you ask for it.
other choices
toyota 103 FIPG (toyota uses this to seal the sumps, timing cases and almost everything on the engine) - this is also called threebond 1207B - set time is 30 minutes - engine can be put in service after that.
Hondabond engine sealant - aka threebond 1107 - its runny but good stuff - Honda uses it on their cars and also motorcycle engine casings. If the dealer says they never heard of it - ask what is put on the engines when they are assembled - its also in their parts catalogs.
General Motors engine sealant - this is threebond 1207 in gray colour, (I use this all the time due to its colour and almost guarantee for no leaks) - setup time is 15 minutes - engine can be put in service in 30.
call up a toyota dealer and ask them for the sealant - if they dawdle and recommend to use bathroom silicone - ask them for this recommendation on dealer letterhead signed by the service manager.
