Thank you sir. The rubber boot was seated and locked but after that the sound still came. Turns out that the Mechanic bent the nuts of the Manifold at time of removing and re-installing. Hence some off the exhaust noise was leaking due to poor fitting and making its way into the cabin. New nuts were used and the sound is now gone.
HOWEVER, the other problem now is that the car is driving very heavy. It used to be very nippy and responsive to acceleration but now one needs to really floor the car to get it to move and its just not the same anymore.
Please could you suggest why this could have happened and how I could resolve this?
While removing the Steering Rack for repair, the Mechanic had to remove the engine top over, spark plugs etc to remove it.
Once everything was re-assembled, the Check engine light went on so the Mechanic asked the car to be turned off and removed the battery terminal for a few minutes to re-set the computer. After this the check engine light went away. Don't know if that could have caused a problem?
I just want my car to drive how it used to
Look forward to hearing from you soon
God bless
