call up cummins Pakistan Ltd and ask for their servicing rates - They have the best test bench and best clean room for diesel work - and they have all proper data for such pumps too.
reason to say the above is that even with a brand new injection pump, if your installation is bad the engine will run bad. - There was a person in karachi who bought a diesel injection pump from UK for his 5 cyl diesel mercedes, after install it was still hard to start, ran bad and sounded like an earthmover - because the install job was hopeless.
After retiming it correct the sound was perfect, then I took his original pump - had it calibrated by cummins, installed it correctly as Mercedes requires and the car was beautifully perfect after the job. - He was quite annoyed on himself for wasting money on buying the pump from UK.
precis = pump calibration is half the job, pump install is the other half. on 4M41 its electronic so the install part is treated as diagnosing the faults correctly - namely the speed sensors output, the rack fuelling lever positioning system etc. etc.
It basically is a zexel built bosch ve pump clone under all that gadgetry - the fuelling is controlled electronically rather than oldschool levers.
