hey guys..
Xulfiqar...brother im in a fix with nissan bluebird sylphy g11 ...its my daily driver car
i use Mobil 1, and change all filter on every oil change ....when i bought this car i took it to INH (Merchanics) in lahore and they sorta tuned it, cleaned plugs, throttle body and some sensor i suppose...and i hoped that it was all perfect ...
Q1 ..These days on A/C at all times, it gives me 8.8, 9km/l though i drive with heavy foot and start/stop situations...when i try to be very carefull..i go upto 10.5 km/L ....any resolution for better mileage?
Q2 ..Got A/C serviced, cooling is all good....but when i drive around 20-30 and the car is supposidely in 2nd gear, now the moment i will accelerate, the car sorta boggles ..and i need to depress accelerator to 70-75% to get it going ..without a/c its seems fine ...any resolution ?
Q3 .. Does the above 2 have anything to do with Cat Converter, if so then how should i go about it
Q4 .. When i took the car for tuning, they only adjusted Idle from computer and that too took them half day to figure out how to do it in sylphy, as whenever they tried to adjust, the machine would revert back to same Idle position. Is there any proper tuning that i should get done? ...If so then what should be included in that?
Q5 .. When the car is loaded, there is some sound from rear left side ..seems like as if silencer is touching somewhere and im not able to go on bumps even at 60 ....or maybe the rear shocks are weak...mechanics say its all fine..but i doubt, there is some problem, since even in Japan people do use them with 4 people onboard, and even the minutest bump would disturb ...something is wrong
Your help would be highly appreciated
Thanks and Regards
