but how do we remove it, the problem we are having is that the power valve is working even at idle
plus how to test the power piston, i mean where to give vacuum?
i pushed the piston down and then blocked the vacuum port, then i let go, it did not stay or even slow down, like it is not sealing properly
we tested this on two carburetors, one which is being used for reference and the other that is being serviced, it acted the same in both the cases
