sorry - I meant the power piston
the power valve is smooth as silk
the power piston is also good but seems a little loose..if the piston doesn't seal good enough, even a new one, that probably means a new air horn is needed?
plus if the power piston is tested using a handheld vacuum tester, approximately how long should it hold at say 15 inhg?
