Thank you brother I'll look that up and do it. Btw, is coolant worth it?
I need a little but of more advice, please help. I was cleaning the throttle body today and while looking at the intake pipe near the air filter box I notice a piece of metal was taped to it to restrict air flow. It can be seen in the picture, suppose my hand is the pipe and the metal was strapped in this position. Upon disconnecting the pipe when I tried to reach the throttle body that was about another round steel object (picture given) attached to the throttle body, I think it is for cng and was restricting the air flow. I removed both these objects and cleaned the throttle body thoroughly using a carb cleaner. The throttle body was very dirty.
So my question here is that I've removed both these steel objects which were restricting air flow and started the car and did the idle relearn process. The car is running so much better with much increased performance now but I'm worried that removing these 2 objects will somehow damage the engine. Please give me your advice on how will removing these 2 things will affect the engine and the fuel mileage?
Sent from my 0PJA2 using PW Forums mobile app
