Sitting here going though the thread from the the first page at 1 30 am, I was at the 10th page when I noticed that xulifiqar bhai said that you should lubricate your iac motor after cleaning. Last Sunday I suddenly had the jazba for cleaning the throttle body and I disassembled everything and got the cleaning done. The car wasn't doing anything wrong, I just did it for fun but after cleaning the iac motor with carb cleaner I put everything back in place without any lubrication... I feel dumb now.. Now I don't have the himat to disassemble everything again so can I spray some wd40 using the long nozzle into the iac valve hole in the throttle body? This will lead to the iac motor being lubricated hopefully. Can I do this?
And another thing, while putting back the iac system to the throttle body I put the gasket along with silicone and screwed it back and the throttle body was screwed back to the intake manifold using the old gasket stuck to the intake manifold, I applied some silicone over there too and tightened the nuts and everything. Pit silicone the the intake pipe too[emoji14]did I do everything right ir does it need some other method of sealing?
I plan on changing transmission oil by removing the pan and everything this weekend. Have exams in an month but this work is just too fun
Sent from my 0PJA2 using PW Forums mobile app
