I found that the blower motor wiring connector was getting hot on my car. Opened it to find that the spades had burned through the plastic and were now touching.
Replaced the plastic connector (praying that the wire was okay, because i can't get brand new spade and soldering a used connector isn't the most beautiful thing)
Sure enough, it gets hot AGAIN. didn't melt while i was checking it, but got hot.
I will solder a new connector to see if that also gets hot, that will rule out the possibility of burnt wire or bad connection.
If the wiring checks out, do i replace the blower motor or is it repairable?
