Salam Xulfiqar Bhai. I have a Corolla 2013, was bought brand new and have been using it since then. It is 83,000kms driven by now and I try to keep it well maintained by replacing fluids and filters on time. I am facing two issues, firstly the car is not as responsive as it used to be, could it be because of clogged catalytic converter because I never got it checked. If so what is the solution? If cleaning then which method is recommended. Secondly, if the AC is turned on the rpm goes down, the engine vibrates and rpm comes back to normal, this happens every time the car is idle or when the clutch is pressed to change gears and doesn't happen when AC is not being used. Also I haven't changed the fuel filter yet, do you recommend changing it at 83k. Will appreciate your opinion in this regard.
