suzuki G10 resleeve? its an open deck engine, pretty tough to resleeve those.
anyway
make sure the piston to bore clearance is set as the factory wants, not as the mechanic wants, same with the bearings. Make sure everything is perfectly in tune when engine is started.
For first run, give it short bursts of high acceleration to 80% of rpm redline - let it slow down itself on overrun (make sure dashpot is working in carby) - about 10 runs are more than enough to seat the rings
Just drive normally after that. - change oil at 500 kms - then follow normal oil change after that.
