Thanks 'Sharo53' and 'hanimughal'!
This solenoid valve idea was there in my mind too and this can be the logical solution! I will look for it in the Islamabad/Rawalpindi market.
@hanimughal: Yes bro I am using the ATS and I think if a solenoid valve is there then we do no need the typical gaskits as we can use a small 50Rs valve to control the gas pressure before the solenoid. I have the provision of 'Battery + -', 'Self', 'Gas Valve' and 'Engine Off' connections in my ATS board. So your suggestion sounds very likely that I can use the 'Gas Valve' spot for the solenoid to on and off. Please correct me if I am wrong. About the gas adjustement according to generator need, I got it from your detailed posts in the other thread and it seems like the generator is getting desired gas supply. I will make sure that the gas is according to your suggested way (about 4 inch flame if lit).
So many thanks for the kind help!
