My car (Toyota Belta 1.3, 2SZ engine) AC compressor had gone bad with a lot of carbon in it. I have changed the condenser, discharge pipe and compressor. The replaced compressor is also releasing carbon and it turns off the engine on idle. I've been told by 2 AC mechanics that it's due to faulty compressor. Both have suggested to not use the sensor based compressor. They have suggested to use Deut clutch compressor ) which is hot item these days for AC related issues). My question is:
1) Would it be alright to use Deut clutch compressor? How can I check if the compressor is alright, before installing it and filling the AC gas)
2) Due to alteration required in order to install Deut compressor in Belta 1.3, I am concerned about configuration of pulleys alignment. Can this compressor be aligned correctly in order to make sure that it's pulley doesn't break the belt, and hence resulting in heat up problems.
3) Any other advice besides what I have anticipated in above two questions?
Please suggest.
@Xulfiqar
