You can easily for 5w-30 if no oil reduction is there. ..Make sure you go for the oil having API SN/SN+, Fully Synthetic, ILSAC-GF-5 ratings. ..If the engine oil is reducing then u might have to get some engine work done else increase the viscosity..
can you kindly be specific which band have all these characteristics? zic shellToyota?
All of them.
But whichever is easily available at your place. Tho shell might not have API SN.
Zic, Toyota (from dealership imported from Japan), Total..
All these can be bought from original dealers. Zic order online.
And the ideal grade is 0w20, not 5w30.
You can go for 5w30 if you can't find 0w20.
0w20 even for 2011 model 177000 kms driven ??
Go for reputed brand if u love your Engine. Amsoil, Mobil1, Valvoline, Kendall etc For local dealerships Total Quartz, Toyota Genuine Oil.
Of course. Check the Japanese manual or any other too. Toyota says 0w20 and if using 5w30 then switch to 0w20 at next oil change. 0w20 is even recommended for Corolla, Prius engines... 1krfe is very tiny in front of them.
And mileage doesn't matter as long as engine is healthy and not reducing oil.
how to reduce cabin noise? doors pins are intacted bt still noisy
Which is the best engine oil for Toyota vitz 2017 model mileage is 30k??
0w20
if used in Pakistan 5W-30 is ideal oil grade.
0W-20 service label in japanese is pasted for Japanese market.
The recommended engine oil grades are 0w-20, 5w-20 and at max., 5w-30.
The recommended brands are Total, Shell, ZIC, Kixx, Caltex / Havoline / Chevron.
5w30 or 10W40 which will be better for good mileage ?
I say again: 0w20 for 1000cc non hybrid 1krfe vitz
Okk Thankyou
I would say none.
5w-30 of course.
If it does not suit, i.e. there are huge oil consumption issues, then best bet would be 10w30.
If it also does not suit, then last resort may be 10w-40, but by then, you will be requiring rebuild / overhaul of the car's engine.
I would say any of 0w-20, 5w-20, and at max. 5w-30.
Prefer 0w-20 fully synthetic, from some respected and reputed brand, and ensure that oil is 100% genuine and original. Oil must also meet API SN / SN Plus and / or ILSAC GF-5 criteria.
Oil + oil filter both must be changed after 06 months / 5,000 Kms, whichever comes first. Do not drag beyond these limits.
Also keep a check on engine oil level. If it drops (although this will not happen in your case), simply top it up.
My Vitz is 2007 model with mileage of 90,000. Which engine oil should I use?Also guide whether I can use Guard Brand Air Filter or should I go for genuine Toyota Air Filter?
