Bro did you read my post above before mocking me and try to be joker.
When you got nothing to test and after short trip you can touch yourself with there is no harm. It's better to check it by touch rather than being over smart, making fun and try to get attention for no reason.
Sorry bro if you found it personal.
Its ok bro. Happens a lot on the web. Brakes are supposed to get hot. Thats how they work. F1 brakes operating temp is above 400. Then dont even work well on 100. There is literally no need to touch and check any kind of brakes. Bigger and vented rotors are needed for sports applications not everyday use.
Has Margalla and cultus same size rotter and clipper ?
What Happened ?
That's my question
they use the same pads so they are probably the same size.
also servo and master cylinder are same ?
You wanna change brake booster ? I have suggestion.
Then share it or I have to pay for the suggestion?
Haha. I have got installed japanese Mira one in my cultus and is working perfectly it's been more than 8 month I am using it with having any issues and braking has improved alot compare to stock booster.
Thanks, can you share a zoomed pic ?and at what price you bought that ?
Is it bigger in size than cultus OEM booster? Can you share pictures. Please
Yes little bigger than original fitted easily cost me 2500 after giving old. Let me finish my Pasta will share you pic.
Forgot 500 for labor charges.
WoW,Pasta sounds yummy.
