@sheharyarali91 sir while we are on the subject just thought to let you know that the formula one interior protectant you are using is also very harmful to plastics and dashboards, itself is written on it that it contains "advanced silicone formula" just means that it contains silicone which causes dashboards to dry out and crack hence no not protecting them but making them worse, it also leaves a very shiny finish which is not desirable , moreover being solvent based it will harden rubber and not suitable for tyres as well, similarly the applicator bad is too much dipped in wax and is full, shows that maybe even and very thin coats of wax aren't being applied, the thinner the coats the better a wax would work, and omar is right about the brush as well, in a while you will notice thin lines on the sidewall of the tyre,
the point is not to pick mistakes but just to point out how you can do so much better both in terms of protecting your beloved ride and making it shine more, thanks
