I`ve noticed a lot is going on in waxing section...let me warn you guys, washing is the most critical part in your detail.....this is where you do the most harm an cause the swirls.......so puttin out my own personal washing technique for you guys.....
Agreed, my lil experience tells me that a good and proper wash makes a helluva difference...after all it is the beginning step of the surface prep...so the foundations have to be right
Wheels, arches, door Jambs
Start with these. When washing your wheels using a wheel brush, the shampoo solution (or wheel cleaner solution) can spray up onto paintwork, and if you`ve just cleaned the paintwork, you'll end up needing to clean it again to remove the dirty spray from wheels! Don't forget to open all doors and boot and clean the doorjambs and the insides of the door (without getting wash solution into the locking mechanisms, I cover these up) - these areas can pick up a lot of dirt as well and it adds something a little extra to open the door and see the jambs as clean as the rest of the car as these areas are often forgotten about.
I am not using a Karchar...just a garden hose, so I do not open the Jambs but hose them closed...I later on open them and clean them with a wet MF...works for me as the deeper parts of the Jambs do not have much dust anyways...(I clean them regularly)
Pre-Rinsing
This loosens up dirt and wets the paintwork ready for washing. Using a hose pipe, direct a gentle spray of water at the paintwork at a shallow angle. If you blast the paintwork with high pressure at ninety degrees to the paintwork, you'll force grit into the paint and cause scatches. Just a gentle spray of water to wet the paintwork is all that is required. If you don't have access to a hose, use a watering can with the rose fitted to produce a gentle spary of water.
A garden hose baby...is nothing but soft
I let the water flow down from the roof and then I go from horizontal surfaces and covering the vertical ones in the end
Shampooing
This is the major stage of the washing process, and the time when most scratches can be inflicted if care is not taken. This removes fresh surface contimaniation from paintwork such as dust, grit, mud, road film etc... Add the correct amount of car wash solution (according to the dilution ratio on the bottle) to your bucket and fill with water to produce suds and lubricated wash solution.The water can be cold, or warm - I prefer warm water as it keeps my hands warm, especially in winter, use the two bucket method. Use two washmitts - one for the top areas of the car (roof, bonnet, upper sides above the wheel arch line) and one for the lower areas (below the wheel arch line, front and rear bumpers). Use a light parallel motion when washing, with out applying forceful pressure that will inflict scratches. If a mark is stubborn and wont come off with gentle movement of the wash mitt, it will require a stronger cleaner such as tar remover or clay. Start from the roof and work down, therefore the large quantities of dirt that form on the lower parts of car are not transferred to the traditionally cleaner upper areas of the car. Try to avoid letting the shampoo dry on the paintwork as this will cause streaks and soap spots, for this reason try to avoid washing in direct sunlight. If you are in direct sunlight, it may be neccessary to wash and rinse a panel art a time. Continue until the car is completed.
My first one shampooing is with a sponge but is done in the flinging mitt style...so that I get rid of most of the dirt through the shampoo with minimum contact...my second shampoo (after rinsing) coat is however massage style with the shampoo poured directly on the sponge...every inch of the car is massaged in the shampoo.
My natural style is that I did the hood and the front fenders first, then roof from one side...then half (above trim) doors, then boot then the other side including remaining roof and last of all bumpers and and door below the trim....so it is pretty close to what you have recommended
Rinsing
Once washed, the next step is to rinse away the soap bubbles and film. If using a hose I first of all use a light spary of water to wet the paintwork (using the rose on the watering can), just like the pre-rinsing step. Then follow this up with a flow of water from the hose (rose off the water can this time). Most shampoos are free rinsing and require this flow of water to make the rinsing water "sheet" off of the paintwork. (This sheeting effect will work best on well sealed and waxed paintwork). On a sealed/waxed car, keep rinsing until the water sheets cleanly off the paintwork and leaves behind only water beads and not flat regions of water. This makes the car essentially self drying! Rinse from the top of the car down.
I let the water flow...and try to bring it to a minimum level sheet which is normally accumalating on the edge of the hood, boot and sometimes a little bit on the roof...however, the limitation here is that Karachi hai...ziyada pani aap baha nahi saktey...plus I have noticed that if wax has been applied 'WELL" and "THIN" previously, the sheeting and beading will be perfect but incase the Waxing has been heavy then there is HIGH PROBABLITY OF FLAT REGIONS OF WATER..yup I do it top to down...give the water its natural flow
Drying
Another risk stage as far as scrathes are concerned. Rather than sweeping the Mf across the paintwork to remove the water, I prefer to pat dry the car. The sweeping of the mf has more risk of inflicting scratches as stray grit particles may be picked up and inadvertantly swept across the paint inflicting swirl marks. Instead, pat dry the car by laying the mf down over the wet paintwork. Gently pat the mf, then lift off the paintwork. The mf will absorb the water to dry the paint. A thin flim of water may be left behind but this will quickly evaporate to leave a sparkling, streak free finish.
After your last post...I have been drying it like that and quite successfully too. However, my weak point has been highlighted as BLUE in your text. How can we tell that how much of that wetness that has been left behind will evaporate and how much will become water marks. In simple words...WHEN TO STOP wiping MF to make the car squeaking dry?
And there we have it - safe washing technique to avoid inflicting dreaded swirls into paintwork.
