As @jaggi told me about the scratches I asked him, how the scratches feels & what you did up till now
Usman answer : Aamir Bahi kuch Samaj Nahee aa rahhh & did nothing to it . I'm shocked.
Than I decided to call him at my place, he was reluctant as it was ""Firiday the 13th " anyway I asked him dont worry & come over so I instruct him before travelling :
1-Take out black box step two and just put it on the wounds ( procedure starts even b4 touching the ride ) ,just want to give a feeling to wound & @jaggi that don't worry(May Hoon Naa) , some other reasons are also there as i want to judge the limit of scratch hiding initially
2--On arrival wipe off black box & feel the scratch , teree tuuuu :o , even Arham & Shaheer were annoyed & want to brake the glass of the ride, of the guy who did this.
3--- Anyway took out the Mother's scratch remover, make a gadi out of rag, as local compound was not available I have only choice left was Mother's scratch remover and F1 polish , to make Scratch remover bit effective ,I wait around 90 to 100 second & keep the gadi less wet to start with , because of the soft ness of mothers SR it took lot of energy & time to finish,
4---- I cut down the scratch in section & every section finishes with the mixture of F1 and spraying water
5----- Scratch remover--ragrai--scratch remover---ragrai--F1--ragariii-- this cycle repeated lot of time, just to make the wound relax and surrounding area safe & live, I finish each working section with F1 wax & wipe off & start the cycle again & again.
6------ At last after an hour 'n' 15 min scratchy feel was gone and scratch was almost invisible , the smoothness is good feeling but this is also the barrier
,I cannot cross that otherwise I start damaging & removing the paint, I asked @jaggi closed your eyes & feel the area , he was amazed :o ""Woo Aamir bahi scratch tuu Khatam hoo gayaa"" & I told him this is 1/2 job done :(, anyway result was good but hiding process Abhee bakee hayy
7------- I was tired that time
, be4 Usman's call i was not in detailing mood , did a coat of black box step 2 & leave it for a cup of tea , after that I removed BBS2 with Lime prime, @jaggi was Like Woo Aamir Bahi Dodo
, I inspect again ,it was getting better & surrounding area was coming back to life in accordance with scratched part , but still work need to be dont.
8-------- Took out speed carnauba & stary glazing by hand & redo it with bit more force with pad, wipe on wipe off , feel it , inspect it , getting better
be4 we can see the scratches from 10feet, now invisible even from 3 feet @jaggi's expressions dakhanay walay theee ,anyway Kaam bakee thaa....
9---------again glazing with the kushta of BBS2 & speed carnauba , first by hand & than bit more force with pad, did wipe on & wipe off , but remember when I said wipe on wipe off , I did wiping for around 5mins & keep pouring the wax if I feel, never do a dry wipe or rubbing.
10---------- Its coming up better and better & surrounding area of scratches were also complementing & shining & scratches were almost invisible , did one last wipe on wipe off with same Kushta & here you go @Jaggi was like unbelievable & I really enjoyed his expression
11----------- I give a final buff with rotary & took out Mother's SynWax to seal the job , tired so another cup of tea with Marlboro & inspecting the area with different angles while Syn was hazing.
12------------ Ok SynWax was hazed , I took out Mother's reflection's final coat Paste & by hand I put it over the hazed SynWax as a wax removing agent & than wipe it off & here you go the area was shining & reflecting , WITHOUT SCRATCHES
13------------- Did wipe on the final bandage of Black Box Step 2 on the wound after the operation & instruct @jaggi to remove it tomorrow morning with BB detailer spray & enjoy.
Yesterday was Friday the 13th & my BD so I try to explain all the procedure & products in 13 steps , Thanks for reading , before & after pic's are below bu Usman hopefully he will also post the day time pictures
Thanks & regards.
[QUOTE=jaggi;3187525]@everyone
Scratch removed By Aamir Bhai
....it took 2hrs
Thank u sooooo much Aamir bhai for taking time especially on ur B.day
