Depending on how much insulation you want in your car, Dynamat is an expensive option .. but it is necessary to go this route if you have a new car.
A cheap alternative, an vulnerable to moisture retention thus acting as a catalyst to start of rusting process, is the carpet underlay. I have noticed some PW friends have done sound insulation in their cars using underlay.
If you go the Dynamat route, you will need about 2.5 bulk packs for your trunk, and not less than four for the cabin. With cost not less than 10000 per bulk pack, this is going to be expensive.
If you want to go for complete insulation, then you will have to use Dynamat inside the fenders, etc ,,,, Total insulation can touch 100000 ... so my advice for you is to think of how much you want to spend .. probably it will help to visit the Dynamat website, and so many DIYs on YouTube.
