Hello there buddies
i have a mehran that is consistently averaging 13.5kmpl to 13.80 kmpl but i have a feeling that I can squeeze out a lot more than this
engine timing is OK
Plugs are good
air/oil filter/oil recently changed
plug wires are good
new denso ignition coil
dizzy converted to electronic breaker, using cuore's setup
so here it goes:
1 - bogging down - the carby float was broken and was replaced along with other most tidbits, everything was cleaned and now the following happens
2 - engine still bogs down, very slightly now, in any given gear. least noticable in 1st and 2nd, but mostly in 3rd and 4th.
3 - cold starting is not nice, using the choke makes it worse(it was same before the carby service). It feels like the car is running rich but there is no noticeable fuel smell from the exhaust, car runs OK when engine is upto operating temp, how to check this?
4 - thanks in advance
regards
