AOA Pakwheelers,
I have been going through the forum but couldn't find any latest post regarding the civic 92-95 engine swap. I have a Civic 95, which I Inherited from my Grandfather, it has about 400000kms on it, and now I think its time to change the engine as its giving me blow-by, otherwise its still a "water throwing engine" except heavy blowby from value cover blowby hose / and when opening the oil cap, its oil/petrol/moisture mist that is being blowed out. I am currently using a DIY oil catch can.
My plugs are always clear of oil, there is no smoke from tail pipe whatsoever.
Two mechanics have suggested that its a piston/rings wear and tear issue. so they have suggested me to buy a new engine.
Now my question is can this issue be fixed, online research showed me 90 % results telling me that its worn out piston / rings. but some says its stem valve seals no sure.
If i want to go for an engine swap, (current engine is 400000km driven so its not a bad idea to change it)
what should i go for, its a daily driver for me.
Your input will be highly appreciated.
