please check on how to do a leak down test.
you should be able to do it at home. using a small compressor like the car tyre inflator. and an adapter that will fit the compressor hose to the spark plug hole.
this will definitively tell you if your rings are bad, or your inlet or exhaust valve are bad.
same case with compression testing. the tester is not exactly expensive. about 3-5k. again do it home. compression testers normally come with a variety of adapters to fit various engines.
