When you replaced the headgasket did your mechanic use a steel or paper headgasket?
Were the headbolts renewed or old ones reused? (They become junk once opened from engine)
Does your mechanic have concept of cooling system pressure tester? Or does he go on âustaad ka sikhaayaâ?
Suzuki m13 is a royal pain to bleed air from, you will need a raised funnel setup to fully purge airbubbles from top of cyl head near cylinder 4
