I am facing issue in my 2014 model GLI with 65k on odo, following are the details:
- My car switches off on road and starts itself as engaged in gear.
- When it switches off, I observe that the temperature warning light turns on for a brief period.
- As soon car restarted, the light goes off as well.
Please note that the meter which shows the heat, always remaining at middle after a few minutes drive. The meter never crosses the middle level but car still shows the temperature warning light just for a brief period. I am always using Toyota coolant, never used water. And yes, the coolant was at the proper level.
What I did to resolve the issue:
- I got it checked by a mechanic who after checking its thermostat, advised to change it and said that it is opening a little late. Replaced it with the genuine one.
- Same mechanic suggested to get my radiator serviced as a safe side. Done that too.
- Get it tuned, like plugs changed, throttle body and catalytic converter cleaned, etc.
- Faced the same issue very next day, went to a electrician to get its fan and other wiring related things checked. Everything was confirmed as working fine.
The car is not showing the light regularly. After last tuning, I went for around 500 kms round trip with AC on all the time and speed between 80 to 120. It was behaving perfectly fine. After few days, car started to show the same problem.
I have spend around Rs. 20,000/- to resolve this particular issue, but staying at the same place as I was before.
Will appreciate guidance of senior members including @capsat , @Xulfiqar , @mehran , @nfssaad , @archon2001 ; @abid110 @
