I imagine it won't hurt anything if your condenser has extra airflow across its surface, but it might overcool the car or cause peculiarities with the mechanical design of the thermostat vs. the intended design temp of the system, especially if the system doesn't run like that by design.
Some cooling systems have the condenser in front of the radiator, running two fans on either side configured push-pull. Some of them have two fans for rad and condenser, with one or both running depending on the conditions. Some use one giant clutched workhorse fan for everything.
In either case, the way it was designed is usually the optimal way that it "should" be. If the fan turns on automatically with the radiator fan, great, but it might also turn off at speed to protect the motor, especially since the effect of air rushing into the car because of its own movement at speed is usually greater than any electric fan can provide.
I'll try it myself and see how the car behaves with the radiator fan constantly on. I know for a fact it causes my car to take way too long to warm up. It's definitely not good for my aging alternator. It's also not good for the fan motor to be forced into moving by anything other than its own power, which it will be at cruising speed.
My fan control setup is to turn on at 85°C, turn off at 80°C, regardless of whether the key is in the ignition. If I turn it off and park it and it needs to cool down, it'll do that on its own by turning the fan on for a little while. Most modern European cars do this.
