Last Saturday we rebuilt its front and rear suspension,,,,,,,,,shocked to see Suzuki fx leaf spring fitted in mehran ,,,,,,,,,left leaf spring was from fx and right one is mehran ,,,,,,,that make the entire suspension out of alignment , the brackets of where leaf spring attached with body are also off set ,,,,they have been welded many many times ,,,,,,,,,,, and in front suspension we replace both cv joints with new chinese made , ,,,,,,, swapped both shocks with new one ,,,,,,,,,, steering rack been repaired ,,,,,,,,, the entire body was so weak because of rust that I am afraid it wont hold more then few months ,,,,,,,,, steering rack U clamp bolts are also weak ,,,,,,,,,,,wish bones 14mm bolt which tights with a nut welded inside body also weak ,,,,,,,,,, after seeing all that I ask mechanic not to open balance rod ,,,,,,,,its four 14mm bolt tights with a but welded inside front foundation are also gone and if we remove them to replace the rubber bush them I am sure we cant tight them back ,,,,,,,,,,,, hand taping them will be the last option ,,,,,,,, I just pray this car holds few months ,,,,,,,,if it breaks then all blame will be on my shoulders
,,,,,, that car really scared me ,,,,,,,,,
