Dear Brothers
Alhamdolillah finally Head work is done.
1. New gasket 2mm thick by CT company (mechanic refused to use Guide)
2. Head faced and now both parts cylinder head and engine block look shiny and clean Alhamdolillah.
3. Radiator serviced.
4. All belts are changed except timing belt as the one I bought was 98R however the existing one was 97R.
5. New engine oil Caltex Havoline 4L.
6. Poured 2 bottles Nasa coolant.
7. New Distributor packing.
8. New distributor ring (japanese)
9. New radiator cap (Futaba Japan)
10. New Tappet packing/seal (taiwan)
11. New oil filter (leppon)
12. Bossil grey silicone seal tube.
no water pump was required.
After all this work done, I did a test drive and all looks OK alhamdolillah but the temperature needle is stands little below from middle point when engine start. I asked the mechanic and he said it's OK. Don't to worry but I am still not satisfied. Can you please suggest and remedy of this issue.
He also said two things to be done immediately.
- Carburetor butterfly is damaged. So need to change or repair immediately.
- There is a play in fan motor. Also he said to buy a new motor a bigger one (kabli) like Cultus EFI which will keep the engine cool.
Can anybody please advise me if these things need to be done and after doing this, temperature needle comes down?
Also what would be the cost of these two things??
Thanks a lot for all of your help and support.
kind regards.
