Hey Folks, I have Cultus 3 cylinder , model 2002. I am the First owner of the car and done through the regular and on time maintenance. From couple of months, I am facing a starting problem on petrol. Replaced and put the New AGS battery but the issue didnt resolved. Rechecked the battery from 2 battery dealers , both said battery is on strong position. I went to the Electrician and discussed with him the issue in detail and he checked all the wiring as the car is CNG factory fitted. He did some work on wiring and the wiring is as per his view, is perfect.I faced the problem in Winter Alot more then Summer. In summer, if I do daily start up, then cultus use to start on First ignition. But if I start it on after 3'4 days , then it troubles. I use to self many time even after every minute. Pushing on to the self again and again,the car use to get starts after 15-20 minutes. 2 different Electrician ( one of suzuki 3S dealer) said that its a Fuel Pump problem and it needs to be replaced. And the mechanics give different opinions. You can say, several mouths'multiple replies ". What you guys think where and what is the Actual Problem exists? and if it is Fuel pump, then which should I go For? I will Appreciate all of your kind replies. thanks in Advance
