time for some funny stuff update -- This time, its the AC (again?
) trying to act funny. Over the past few days, i noticed that the engine wasn't increasing its RPM on its own when I turn the AC on (which isn't normal)
so i popped the hood and found out that (surprisingly) one of the return (vacuum) pipe was disconnected -- weird -- the tiny pipe that forms a connection b/w the distributor and that small something/switch (i'm forgetting its name) which is supposed to increase the engine RPM when AC is turned on.
anyways, I plugged the pipe back in (since it was only one that was disconnected, so I'm confident that I didn't mess up the pipes/connections) ... as a result that auto increase in RPM was back.
Sadly, that only lasted for a day and today, I noticed very small/nominal increase in RPM when I turned on the AC. Not a considerable one like it used to be .. because of that the cooling dropped significantly, specially when I'm at a signal or a jam. Please note that Fan runs direct when AC is on.
one more funny thing is that since fan is wired to go direct when ac is switched on. I've noticed that whenever the compressor trips (turns off) .. fan keeps running (even when temperature needle is well below half mark)
another funny thing i noticed is that on a very high RPM like running on a highway with 100KM/h or so .. AC trips randomly causing a gradual drop in cool air -- to the point that I end up lowering the window of my side to get some good air .. I feel like it gets overheated?
not sure. but then suddenly the compressor wakes up and starts running (while car is still doing 100-100+ KM/h.
..and another
yup ..another thing is that I do hear a whistle/hissing sort of noise (for a while) from or near the evaporator unit mainly when the AC is first turned on -- or if it turns on automatically after tripping.It goes away after I press the pedal (accelerator)
I've found that AC works optimally when the car is running b/w 40-80KM/h even if I take it out around 2:00PM these days.
Please note that, AC was services (including gas filling) back in summers 2017.There can be a possibility of decrease in gas ..right?
any thoughts respected brothers? @nfssaad @muhammad.irtiza @omersiddiqui5482 @dayrider @Xulfiqar
