(Sunday, June 23, 2019)
So today I drove my car to the mechanic. Surprisingly, the car started on first self, and drove smoothly to the mechanic (which wasnt near), and did not reduce water.
When I reached the mechanic, it wasnt even that hot. He inspected the car and found that the fan wasn't converted to Auto at all, it the relay was not working. Truly, a product of throwing acid on the engine bay, which is slowly eating away at all components.
He assured that the head gasket was okay and he replaced the relay. This time it was a guine Denso Replay, not the rs.50 MGM Relay:
Then, with cash spared, I headed over to the infamous Sabir AC to get my car's AC checked. Turns out the column pipe was ruptured badly. It was welded.
After column pipe was welded, the AC was properly serviced and topped up with Honeywell gas.
When he got to hear about the troubles with my car, he looked at it, serviced the radiator for FREE and added foam between condenser and radiator for proper radiator cooling.
Overall, the car is back and running as it should, but I will keenly observe car's behavior over the next two weeks.
