Need Expert Help/Advice
Problem # 1: I have Cuore 2006. In morning when i start and move the car there is no problem. Some time when the car is stopped 1st gear does not engage easily. if I release the clutch in neutral position, press it again and apply 1st gear it engages. Gear Oil level is ok my mechanic says that Gear Oil needs to be changed but he also saying to change Gear Oil after few day when weather is cold otherwise the gear box will start giving sound (gung). Anther mechanic said not to change the Gear Oil. Pls advice what to do.
Problem # 2: When 4th gear is applied and upon release of clutch i hear some strange sound. (which I am unable to describe) also it vanishes on acceleration (high RPM) No sound when clutch is pressed. As per my judgment it is sound of clutch bearing. Pls help
