Yes one way you can test that is bit tricky. You have to lift up both wheels out of ground , donât forget safety matters must use proper jack stand. Put shift to D and accelerate until speedometer touched al least 80km/h keep steady and monitoring your engine rpm tachometer reading and note down , now have drive on road if you give full trust to meet 80 speed quickly and when reach check your rpm on this stage , if you found rpm greater than without load , itâs mean someone is bad cvt belt slipping , thatâs my personality suggestion for test, if any tool available I donât have idea .
