Yes thats where the diagnosis started. I had the car for 3 months now around 23K milage in japan and 6K in khi. It was going smooth until this noise started.
Actually car was hit from right side in japan and wheel was a bit bent. We thought noise was due to shocker. So I had its right shocker repaired through Afzaal in rubber market and he referred to a alignment guy who pulled the chamber out and wheel was aligned. However noise still there.
Alignment guy said its wheel bearing noise. So I took car to mechanic who said wheel has very light noise but actual noise is in middle of axles. His diagnosis was that he has to open gear for further investigation. Then I went to Khan Motors in defence and he took 2 hours (and Rs. 1000) to rule out bearing, axle and suspension noise. He also concluded it is gear noise and that he cannot repair it due to uncertainty about parts.
My mechanic is ready to open gear but labour is at least 8K he says and parts separate.
Noise is increasing day by day....
