<style type="text/css">p { margin-bottom: 0.08in; }</style> Step 5: Clay bar the exterior
What is clay bar you ask? Its exactly as the name implies, a bar of clay (treated with synthetic stuff obviously) which is great at pulling extreme grime right out of your car. This includes brake dust that has firmly settled into your car's clear coat, tar, and numerous other paint contaminants.
This is perhaps the most difficult part of the entire session, clay bar'ing your car requires an extreme amount of patience and practice. For any detailing newbie I would suggest reading this step thoroughly and understanding the whole process properly. You can literally destroy your car's paint / clear coat if you do this wrong, due to the abrasive nature of a clay bar. Its almost 7:10 AM at this point and the sun is up, so there is sufficient sunlight for me to start the process.
- The surface of your car may have gotten minor dust at this point, whack it off using a towel.
- The surface of the car needs to be lubricated in order to run the clay bar over its panels. With the clay kit, Meguiars provided a quick exterior detailing spray which will be used for this purpose.
- Choose a panel to work on, I started with the hood of the car. The key is to work on small portions rather than entire panels.
- I sprayed a small portion of the hood with the detailer
- Then take out the clay bar and prepare it as follows:
- The clay bar comes as a thin slice and it needs to be kneaded into a pliable block.
- Use your fingers / knuckles for this and and roll it into a neat square and knead it some more.
- Once its in a shape that you can easily maneuver on the surface of your car, you can start.
- With the clay in the proper shape, I ran the bar over the lubricated portion with a small amount of pressure. This should be a painless process and the bar should glide smoothly over the lubricated panel. It will leave a residue as you progress through the panel.
- Once you've done the portion, take a look at the underside of clay bar. It will have contaminants on it, these now need to be rolled into the bar, so start the rolling and kneading process again to reveal a fresh side of the bar.
- Once you're done with a full panel, you can clean out the residue using a high quality microfiber towel. I used the one which came with the kit.
Warnings:
- If you happen to drop the clay bar, DISCARD IT, do not reuse it. You can literally scratch the paint right off your car if there are heavy contaminants in the bar.
- Always keep the surface lubricated, failure to do so will result in the clay bar eating up your car's clear coat
- Keep watching the base portion of the clay bar for contaminants, when it becomes heavy with them, take caution to knead / roll into a new side of the bar.
You can now see the results from just a dose of clay bar:
