@all..
which one of these one should be looking at...and yahaan konsa available hai?
[edit] D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
1992-1998 Honda CRX VXi EG1 (Japanese Market)
Displacement : 1493 cm³
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.3:1
Power : 130 hp (97 kW) @ 5800 rpm & 102 ft·lbf (14.1kg/m) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Head Code : P08
Fuel Control : OBD-1 MPFI
[edit] D15B (D15Z7) (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp (97 kW) @ 7000 rpm & 102 ft·lbf (14.2kg/m) @ 5300 rpm
Fuel Control : OBD-2 MPFI
they both have same hp....but one has 3-stage vtec ...came from 96-99 while the other one came from 91 to 99....
