@testdriver and asadscorpio:
in recent rains, sufficient water penetrated in the foot area, more on left side and less on right side, only front area not the rear one.
two rubebrs were missing on the floor on both sides which have been placed now.
Their is water flow pype beneath the black AC fan blower cover in the engine bay, it was choked with mud earlier, now its opened but i doubt that still water does not flow out from it. if its still choked, then water may be flowing inside the sitting area? is it so...
is there any other culprit area to be checked?
Another thing to ask, that there is almost 2 to 3 inch thick foam insulation below the dashboard wall (adjacnt to engine bay). its probably to resist the engine heat?
if i intend to remove it and place new foam/namda on the floor and on wall, should the thickness of 2-3 inch be maintained, if so, with ordinary foam/namda or???
