@xulfiqar Sir
I was reading older posts in the forum and found this one
I have 1990 Toyota 2.0D 2C engine, i set Nozzle at 145 bar break pressure and Pump timed at 0.8mm befor TDC
I just followed a manual i had, but now you mention different values for Old.
By old do u mean some specific older models or do you mean sufficiently used car.
I have 172k on the odo, what Pump timing and Nozzle break pressure would you recommend.
My engine reduces oil, that seems to be increased since i timed the pump to 0.8mm b4 TDC, it was previously set at 0.64 mm.
