CV = camry/carina with C engine
CE = corolla with C engine
the nozzle spec is quite right 130-150 bar
Do not deviate from factory spec, rebuild the pump back to factory spec and the injectors too. The OE specs are good till the service limit of the condition of the engine.
e.g. if the compression pressure service limit is 300 psi - the factory spec will work, if its 200 psi (well it wont start) - but that doesnt mean you then tinker around to make it work - rebuild the engine, thats what the service manual was made for.
