@xulfiqar
Can u please also comment on my above mentioned compression test.
2ndly, these are my deductions for choosing right specs from these pages.
My car is CE95, 2.0D, 2C engine.
Presetting Full Load injection volume is categorized as follow:
a CE70
b CE80, CM(STD)
ruled out both of them, as they are 1C-L engines, CM is ruled out for reasons given at the end.
c CV
ruled out, as engine list indicates all turbos like 1C-TL, 1C-TLC, 2C-T, 2C-TL, 2C-TLC, &3CT series which is out of scope of my manual.
d CT (w/o HAC), CR
Most Probably THIS, as both these series are in 1C-L and 2C-L engine category, my chassis CE95 is also in 2C-L engine category in wikipedia.
e CT (w HAC)
Ruled out; HAC, i understand, is Hill-Start Assist Control
f CM: Opt High Altitude
Ruled out; this category has both 1C and 2C engines with/wihout turbo, but they are liteace/town ace vehicles, not sedans like CT.
Inspect Injection Volume (at various RPMs) categorize cars as following:
CE70
CE80, CM(STD)
CV
CT (w/o HAC)
CT (w HAC)
CR
In contrast to previous list, CR & CT(w/o HAC) are separate. I think CT(w/o HAC) is closest to my car although it has turbo variants, else CR category is 2C engine mostly but its a liteace, not sedan.
Should i go ahead with using CT(w/o HAC) specs??
Other tables have less categories and its easier to choose specs their.
Now i have noticed, in 2nd table where my closest CT(w/o HAC) & CR are separate, data is exactly the same.
Only difference is Adjusting Lever Angle
for CT its 13-23 degrees, for CR its 3-13 degrees.
what is meant by this?
